Results 1 to 10 of 11
Thread: Railing job.
    3,953
    Cool Railing job.
    This is what i have been doing at work for the last few weeks. Normally we make these work platforms and they have 2x2 sq tube posts and welded cross bars from 1 1/2" tubing. This batch of platforms has 1 5/8" formed railing with cross rails that need coped. So i have like 390 rail sections to fit and tack together for the welders. Plus they have pockets that the rails sit in and need to all be removable. I have found the quickest way to cope the 1 5/8" tube is with a grinder and 36 grit sanding disc. Like 30 seconds per end. Just measure between the uprights and add 1/2". Then scribe a line 1/4" from the tube end and grind to the line while feathering to the center of the tube then roll the tube 180 degrees and do the other side. Piece of cake...Bob
    Aug 2012
    Hermiston Oregon
    286
    Its 1-1/4" sch.40 pipe not tube.
    Im going to search for a tool and post a picture. this tool is design to shear offthe right amount. For the fish mouth. All thats needed is a hydraulic press.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    3,953
    We have an iron worker and the company bought notching dies for it. But in the 8 weeks its going to take to fab up these platforms the hole punching station will be down because thats where the notcher goes. Plus the iron worker is a long way from my bench and its quicker for me to grind as i have been doing. No if the iron worker was right next to me i would use it, but we still can't punch holes..Bob
    Aug 2012
    Hermiston Oregon
    286
    Well heres the picture for anyone o
    Else who hasnt seen or used one. Just slide the pipe in and notch takes less than 10seconds to do both side with minimal to no grinding.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Jul 2009
    Australia
    1,031
    Nice work Bob
    Coping looks pretty good too
    Tubes they will drive you nuts
    Ji
    Grip it and Rip it
    Aug 2013
    15
    Bob
    Excellent craftsmanship.
    To heck with the tubing notcher - your technique sounds faster and looks fantastic when finished.
    3,953
    Its 1 1/2" 1/8" wall tubing. We were using 1 5/8" but changed somewhere along the way...Bob
    Wa
    643
    Quote Originally Posted by eecervantes83 View Post
    What brand is this tool? Anybody have a link? Thanks.
    alabama
    751
    Why in the world would you not use a hand notcher for this ?
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    3,953
    Quote Originally Posted by fabricator View Post
    We don't have one. There are 10 different ways to do this job for sure and some are better than others and i am just showing how to do it minus the notchers most people don't have..Bob
