    Default 3G code best rod to use
    I'm doing a 3G code at the moment and I'm using special 7016 rods, should I be using 7018 instead? What's more closer to work situation? Do I run them hot? I use the 7016 on 10mm steel at 105 dc-/+.
    Aug 2012
    Hermiston Oregon
    239
    1/8" 7018
    And the temp depends on your machine.
    Are you weaving or stringers.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Weaving, my instructor prefers them.
    Midwest
    765
    What does the code say to use?
    Oct 2012
    Neosho Mo
    73
    Quote Originally Posted by ShieldArc:313794
    Herein lies the the answer
