    1,916
    Default Roof gutter collectors
    Got a call to make new collector boxes for the downspouts on a gas station canopy. Old ones were completely rusted out. The rainwater flows to four of these that are welded around the main posts. The problem was since it is a "live" gas station no torching, grinding or welding could be done. I designed an aluminum box with three sides & the fourth side bolted on. Cut the old ones off with a sawzall as close as I could & mounted the new ones by drilling & tapping into the columns. Very sore legs as I was up & down a ladder while doing the job. The canopy is 14' to the underside.
    DSC00354.JPGDSC00432.JPGDSC00412 (640x425).jpgDSC00415 (640x425).jpgDSC00416 (640x425).jpg
    In the first pic you can see the gutter/trough is rotting out also. After he paid me for this he now wants me to patch these up. Everything is steel so it's rotting out from lack of maintenance over the years. Somebody tried patching the top side (inside) by laying some kind of panel in & gluing rubber over it. Didn't work out so well. My plan is to bend up an aluminum cover to go over the outside & screw it on with lots of sealer/caulk. Then go up top & try to seal it with some sort of roofing tar etc. Problem now is it is November & not to many warm days to apply sealers & stuff.
    Wa
    656
    You should use a really high quality gutter sealant. This stuff here works really good. Key is to get it as clean as you can get it. Lacquer thinner with white rags till they come back white after wiping. http://www.vintagetrailersupply.com/Alcoa_Plygem_Gutterseal_p/vts-138.htm
    Aug 2013
    15
    What excellent craftsmanship! The bends, cuts, and welds are gorgeous!
    **** shame your client had you paint these collectors - he should of gone for aluminum paint everywhere else!
    Nov 2012
    Northern Arizona
    557
    Nice work. Looks like problem solved without blowing anyone or thing up. While I would like to see welding or grinding sparks flying around a gas station this was probably a better end result. And nice craftsmanship as well.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Dec 2012
    Front Royal, Va
    64
    Yea that is awesome work. Should outlast the canopy itself.......
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
    Jul 2014
    4
    beautiful work
