Results 1 to 7 of 7
    Nov 2013
    Default aluminum welding please
    I am interested in a miller 211, the manufacturer states it WILL weld up to 3/8 aluminum with the spool gun, is this true my dealer says NO?
    It is a 160 amp machine with I think a 100 amp spool gun, but miller claims it will do 3/8, you guys know, will it do that aluminum at 3/8 max?
    Aug 2012
    Hermiston Oregon
    286
    It will do 1/4 fine thats what I done so far with no issues and good penetration. My only issue is I melt up the tips quite a bit .but thats either me or the spool gun overheating.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Wa
    656
    That is the rating for a single pass weld. Pre heat, joint prep, and multiple passes can accomplish more if the operator knows what he/she is doing.
    That said, I wouldn't buy a 211 with the spoolmate 100 and expect to blast 3/8 aluminum all day everyday. It's not made to handle that. If that is what you need, a 252/251 with a 30a would suite you better.
    Nov 2013
    Toronto
    46
    I definitely agree with Cgotto6, I work mostly with 1/4" thick materials so I always try to buy a machine that can double that. I almost never have to worry about duty cycle or running the machine too hard. As long as I have $$$ to do so lol.
    May 2013
    East Tenn
    148
    I second that
    Default 3/8 Alum
    Ditto all of the above
    In saying this we have 350 amp machines running .064" wire and we squeak by doing fillets welds on 3/8" plate, 1 pass. It eats up the contact tips and nozzles though.
    If we wanted to make welding 3/8" easy we would use water-cooled guns and 1/16 wire.
    We will do fillets on 1/4" in 1 pass no problem
    Butts welds on 1/4" and 3/8 are multi-pass.
    Aug 2010
    1,179
    Quote Originally Posted by jtlikestobuild View Post
    What machine do you have? My 350P eats 1/2" for lunch. And I run 3/64" wire. In fact the 350P-aluminum welds it even better.
    Try 75/25 Argon/Helium for cover gas, 5356 which burns hotter due to the mag, and apply "Loctite SF 7900 Ceramic Shield for Welding" to the nozzle and tip to keep them clean.
    That being said, to the OP, I would not depend on the 211 to do what you want. I would step up to the millermatic252 or equivelent with run-in control, which is so very important.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
