Results 1 to 10 of 12
    Oct 2013
    4
    Default M-295 and M-295P Arc Wekders - Need more info
    Hello,
    I recently acquired two Arc welders. One is an M-295 and the other is an M-295P. I searched for the manuals on the site, but didn't come up with any results. Mostly I need to come up with the power requirements for these two. also, they didn't come with any leads for the ground or the stinger. What kind of attachments do these welders take?
    Nov 2003
    3,329
    Could you give us more info on them and some pics??
    serial numbers??
    front panel??
    to help us identify them...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Los Angeles
    2,908
    Looks like 78amps on 240v from this image
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Oct 2013
    4
    Quote Originally Posted by H80N View Post
    serial numbers??
    front panel??
    Sure, here are some pictures.
    Here is a link to some more:
    http://s42.photobucket.com/user/Fran.../MillerWelders
    Los Angeles
    2,908
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
    Oct 2013
    4
    Ok, thanks much. I'll give that a shot.
    Am I correct in seeing that the M-295 takes 94 amps?
    http://i42.photobucket.com/albums/e3...s/IMAG0359.jpg
    The M-295P it looks like takes 78 amps.
    http://i42.photobucket.com/albums/e3...s/IMAG0353.jpg
    Feb 2012
    Wa
    600
    You should post the serial numbers.
    Oct 2013
    4
    There's two pictures above with the serial numbers.
    M-295 M256342
    http://i42.photobucket.com/albums/e3...s/IMAG0357.jpg
    M-295P P337953
    http://i42.photobucket.com/albums/e3...s/IMAG0355.jpg
    Apr 2010
    278
    I saw another pic of an M-295 (non-P) and it does say 94 Amps for 230 V input.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    Los Angeles
    2,908
    Quote Originally Posted by Francopacks View Post
    and those are most likely RATED amps. I can't find the manual for those machine either but I imagine you are looking at 150 amp Circuit
    You might be able to run it on a smaller circuit at lower power, don't know how much those machines use just sittin' there before you strike an arc.
    Ed Conley
    MM252
    MM211
    TA185
    O/A set
    SO 2020 Bender
