    Jul 2010
    Southeast PA
    19
    Default Multiple TIG torch setups
    Hi,
    I was wondering how you experienced TIG guys set up multiple TIG torches hooked to the same machine. I'm just a home shop guy, but I have three torches to do various projects with. A 350A water cooled one, a 17 sized 150A, and I just picked up a wp-24 size for micro projects. Since it's such a pain to change power adapters, gas and water connections, my thoughts were make a panel/manifold of sorts so I can have all three of these torches hooked up simultaneously. Might need a valve or a switch to direct gas & power, but that's the idea. Just would like some info on how this is done in a professional environment.
    Dec 2009
    Streamwood, IL
    87
    There is a device, called a Versa-tig, that is designed exactly for this purpose... But hang on to your checkbook. Big bux
    _kevin
    Syncrowave 250 Analogue
    Maxstar 200SD
    Maxtron 450
    IntelliTIG 40
    S64M Wirefeeder
    Non-Blue:
    Hypertherm PowerMax 1000G3
    Lincoln Precision Tig 275
    Lincoln WeldPak 155
    Sep 2009
    Colorado
    238
    Default Sycrowave style connector
    The Miller Syncrowave connector hooks up the gas and the power at the same time, so for me it is very easy and fast to switch torches. Plug in the connector and turn it 1/4 turn; the hard part is leaning over to reach the connector. I have a 17 type and a CK-9, I believe. I prefer the smaller CK-9 torch unless I need to turn the power up. But both of those torches are air cooled.
    The Syncrowave connector is a variation on the DINSE connector, I believe.
    You could probably build an adapter, using the Syncrowave type connector, if you wanted to go that way.
    If you only have one water cooled torch, you could leave the water hooked up to it all the time.
    Quick-disconnects are available for gas and water. If your welding store does not have them, an industrial supply place will. I think if you have quick-connects throughout your system, changing torches will not be a big deal. My guess is that you are having to use tools to connect and disconnect various hoses.
    http://koolance.com/help-quick-disco...toff-couplings
    Certainly you would not want to waste gas running through a torch that you are not using, so somehow you need to switch the gas from one torch to another, if you go the manifold route.
    I would be interested in what other folks do also, however.
    Richard
    Jul 2010
    Southeast PA
    19
    Quote Originally Posted by karchiba View Post
    Yeah, that's slick but way overkill for me. My machine is a 330A/BP, so it just has studs for the power connections. All my torches have valves in the heads, so the gas can be connected to all of them at once. And the water can stay connected to the 350, already have a valve on that going into the machine. Oh and there's also the stick welding lead too. Shouldn't be a problem to rig up a panel. I'll shoot some pics when I get it done.
    1,928
    I switch back & forth between a #9 & #17 torch on my machine. I have one torch cable hooked to the machine & just switch the torch itself. Takes about 1 minute to do. These are both single hose torches.
    I would look into quick connects here since you need a water cooled torch also. http://www.arc-zone.com/index.php?ma...ex&cPath=5_219
