Thread: back purge
    West GA
    71
    Default back purge
    can you all show someone how to back purge a bucket to repair the pin holes in the bottom. And what all is needed to do so.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    what kind of bucket???
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    West GA
    71
    Default stainless
    the bucket is stainless
    Dec 2012
    Simcoe Ontario
    104
    Default back purge
    Cover the open end with say cardboard taped to it with the argon hose going in and some kind of small opening at the top. Argon is heavier than air so as long as the vent is at the top it will work
    Oct 2011
    Minnesota
    54
    A question on back purging SS. Is it OK to use nitrogen for the back purge. Thanks!
    Tim
    Many cordless tools...........
    2 cordless hammers
    2 cordless punches
    1 cordless chisel
    2 cordless screwdrivers, 1 + and 1 -
    and a cordless adjustable wrench that also doubles as a hammer.....
    Oct 2013
    10
    Default back purge
    We used nitrogen all the time at my previous employer. I believe it was cheaper than argon. Just make a small hole in the cardboard about 1/8 to 1/4 in diameter for the gas pressure to escape. Make sure you have the cardboard fastened really good. I would purge it really good and set the flow meter at about 5 to 7 lbs as you weld. If the weld starts to blow out at you, stop and either make the relief hole bigger or lower the purge gas pressure.
    Oct 2011
    Minnesota
    54
    Quote Originally Posted by bubbaweld View Post
    We used nitrogen all the time at my previous employer. . . .
    Thanks! I have N2 in my car tires so have to get set up to "air" them up. So I'll be basically set.
    Tim
    2 cordless hammers
    2 cordless punches
    1 cordless chisel
    Apr 2010
    304
    A research paper on Nitrogen purging from the AWS site: http://www.aws.org/wj/supplement/WJ_1975_01_s12.pdf
    Looks OK for Nitrogen.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    West GA
    71
    thinks for all the info it worked great for me
