Results 11 to 12 of 12
    Oswego IL
    742
    Default weld away...
    That diff should be cast steel, they weld very easy, also i highly doubt the diff is bent. I have seen them gernade from heavy tuned trucks pulling 30k loads.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    Oswego IL
    742
    Default forgot to mention
    That diff has a removalable center section. Think of a larger ford 9". Diff should be a dana 80. Again as long as the axle shafts pull easily, weld it up and go, likely the pinion nut came loose because someone reused the nut or failed to torque to the proper torque.
    Kevin
    XMT 304
    Miller Spectrum 625
    S22a
    Miller Legend 302
    Lincoln LN25
