Results 1 to 8 of 8
    407
    Default Millermatic 211 wire question
    guys,
    getting ready to purchase a new millermatic 211. somewhere i think i seen it can take a 4# or 8# spool of wire.
    the LWS said it can take a 10# spool.
    i would like to get the biggest spool i can, but dont want to order a 10# if it wont fit the unit.
    any help would be greatly appreciated, thanks
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Apr 2011
    367
    I have a 10# in mine right now.
    Just For Home Projects.
    2,927
    It will take the 10# spool
    Apr 2013
    metro Detroit
    92
    I have 10# of .035 flux core
    Jun 2013
    PacNorthWest
    64
    The limit is the SPOOL diameter, which on the 211 is 8 inches. It's a bit confusing, because a lot of places don't tell you the spool size, only the weight.
    Anything between about 8 to 12 pounds should be an 8" spool -
    On my mm252, I just finished a 33 pound (12" spool" and found at the LWS that a 44 pound (STILL 12" spool) was noticeably cheaper per pound. It's just got a metal frame spool and more wire wound on it.
    HTH... Steve
    Sep 2009
    South Carolina
    571
    Default Indoor Welding
    woops thought I started a new thread. Sorry
    Illinois
    627
    I use Lincoln L-56 .030 wire and it is a 12.5 pound spool in my 211.
    407
    thanks for the info guys.
    my MM211 is on order and also got a 10lb spool of 70s .035".
    SyncrowaveŽ 200
