Results 1 to 10 of 12
    Aug 2004
    Milan Michigan
    1,833
    Default Converting MM to inches
    In my steel book it says 1 MM dec. equivalent is .0394 when I x that x 100 I come up with 3.94 but the book says 100 MM is actually 3.937
    The decimal equivalent for 100 MM is 3.937 so when I devide that x 100 I get .03937
    If I take .03937 x say 78 MM I come up with 3.07086 but the book says its actually 3.0709
    What am I missing.
    The fact that they are rounding
    Oct 2009
    306
    Simply rounded the last few decimal places to keep it simple. Unless you are measuring precision machined parts there is no need to be exact down to the 4th decimal place.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2011
    430
    They are rounding up. What are you doing that requires that level of accuracy? That difference is well within the tolerances for cold rolled steel in my information.---Meltedmetal
    May 2013
    Cantonment, FL
    76
    The chart is rounding to the nearest 10-thousandth inch.1 MM = .03937 but it is rounded to .0394 for the chart"If I take .03937 x say 78 MM I come up with 3.07086 but the book says its actually 3.0709"Again, this is due to the chart being rounded to 4 decimal places - your 3.07086 rounds to 3.0709.The chart at http://mdmetric.com/tech/cvtcht.htm says for greater accuracy when converting MM to IN - divide MM by 25.4. So, in your example (78 MM to IN) -- 78 / 25.4 = 3.07086614173 (which would be rounded to 3.0709 in your chart)
    Northern California
    214
    Default .039371
    Use .039371 for decimal/millimeter equivalent.
    100 X .039371 = 3.9371.
    78 X .039371 = 3.070938
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
    Aug 2004
    Milan Michigan
    1,833
    Thanks guys, Yea I finally realized that, I'm just not used to rounding up and was surprised that alro steel did.
    When they were teaching us the metric system 30 plus years ago they should have stuck with it.
    362
    inches to mm= multiply by 25.4
    mm to inches= divide by 25.4
    For most shop work, that is close enough.
    Sep 2012
    AZ
    66
    Default converting mm to in, etc.
    To get an answer without any loss of precision simply open up Google. In the search area type in, for example, 100 mm in inches. It has a built in calculator and will display 3.93701. You can, of course, also go from inches to mm. For example, type in 3 inches in mm and you'll get 76.2.
    You can convert light years into yards, or fathoms into furlongs. Try it. It will do any conversion!
    4,466
    Buy a metric tape measure,,, ha
