    Apr 2013
    metro Detroit
    92
    Default what size leads do I need (gauge)
    Hey guys I just bought a used bobcat 250, but it has no leads. So for now I'm looking at getting 50' lead. But not sure what gauge I would need for 50' @ 250amps. I would probably never run it at 250amp but just in case I want leads that can handle it.
    May 2010
    Central CA
    785
    A good size cable for a 250 is 1/0. Plus it is a nice size to work with.
    If you are worried about the duty cycle you could up the size of the work/ground to 2/0.
    If you can smell the cables they are to small.
    But really 50' of 1/0 for the stinger and 50' for the ground should handle all but 250amps all day long.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Feb 2013
    14
    I RUN #1 on mine - 60 Ft Stringer - 40 Ft Ground
    The main thing is not to panic or get excited
    Bobcat 250, Extreme 12VS, MM 211
    Meltabo,Milwaukee, Porter Cable,Dewalt
    Victor O/A, Ingersoll-Rand
    Evolution Rage 2, 40 AMP Plasma
    Jan 2013
    North Carolina
    6
    I use 1/0 guage on my bobcat I have 100ft of lead never had a problem
    Sep 2006
    south west Michigan
    81
    If you d'load the OM from this site there should be a section with recommendations for amperage/lead length.
    Apr 2013
    metro Detroit
    92
    Thank you guys, it looks like 1/0 is the winner. I looked for a manual, but could not find one. I'll look again after it's delivered, might be entering the wrong numbers
