Results 1 to 10 of 14
    Sep 2013
    18
    Default Aluminum Wire Question
    What's the difference in 4043 and 5356 wire. I need to weld up a heavy duty Jon boat. Which wire should I use. Thanks for any advice.
    Apr 2013
    Southeast idaho
    30
    With aluminum there is different compositions, just like with steel there is low carbon, medium carbon (a 36) and high carbon,. You need to figure out what type of aluminum you'll be welding and that will tell you which wire to use… if you use the wrong wire your weld will break right down the middle
    Dec 2010
    377
    I do a lot of aluminum work and I never really looked at the wire I use. I took a look a few minutes ago and I have been using 4043. I weld tool boxes and I also do boat repair with it and never had any problem with it.but i'm with you on this one and would like to know if you have to match the wire with the plate or if it even matters?
    Nov 2003
    3,721
    Default Aluminum Welding Guidelines...
    Maxal Aluminum Welding Handbook..
    a really good overview for TIG and MIG
    including setup, parameters for different alloys and GOTCHAS...
    http://www.maxal.com/files/QuickSite...g_6-11_doc.pdf __________________
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    In a nut shell,
    4043 has a much higher silicon content which results in improved fluidity (wetting action). it is also less sensitive to weld cracking. Very easy to work with.
    5356 has lower silicon which makes it a little more difficult to work with, but much higher magnesium content which produces a stronger weld.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Aug 2004
    Milan Michigan
    1,879
    I'm not a boat expert, but most boats that live in a salt water atmosphere are probably 5356 which offers better corrosian resistance.
    4043 is a little easier to work with smooths out better while 5356 is more of a structural wire for strength.
    I'm not sure what a john boat is but I have fixed alot of small aluminum boats that are in fresh water small lakes with 4043
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    May 2012
    27
    Default aluminum wire
    I use 5356 on anodized aluminum or aluminum that is not new. It welds awsome on aluminum that needs alot of cleaning action. If your going to anodize the aluminum 4043 is your ticket. Hope this helps. Good luck
    Dec 2012
    Front Royal, Va
    64
    Huh? Anodize 4043.
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
    Nov 2010
    Oregon
    45
    You don't want to weld anything that's going to be anodized with 4043, the weld will come out very dark, a piece that will be clear anodized, the weld itself will be almost black. Use 5356 alloy only.
    Miller 350 LX Tigrunner
    Miller 350P w/XR-Pro
    Miller 250MP w/30A spool
    Miller 211 Autoset
    Hobart Tigwave 250
    Hobart Beta-Mig 251
