Results 1 to 7 of 7
    Oct 2013
    Default Different Regulators for 100% CO2 vs 75/25
    Hi, I'm a newbie and just received a Multimatic 200. In watching the different setup video's the one for the MIG on steel with 100% CO2 stated that I shouldn't use the regulator that came with it. The setup for 75/25 steel did not.
    Why is this?
    Thx - Steph
    Cave Creek Az
    1,097
    Reg numbers might not be as accurate. I have been using them for many years with both gases, and most of them have a dual scale. Just need the adapter nipple for the 75/25 reg to run it on co2
    Apr 2012
    Ohio
    47
    Liquid in CO2 tank, makes the vapor gas very cold. CO2 regulators are made with that in mind as well...
    Dec 2011
    444
    I was told that if one was going to do a lot of pure co2 that a heated regulator would be best as the standard ones can suffer from freezing with pure co2.---Meltedmetal
    Oct 2013
    10
    Default 100% co2
    Back when I first started CO2 was all we used,welding all day long using a dual stage flow meter. The gauge would get frost on it but would never freeze up. You should not need a heater for it. I have also used single stage Argon/Carbon Dioxide regulators with straight CO2 with no problems. For myself I like to use a C-25 mixture.
    Aug 2013
    102
    Running outershield elite 1/16 at 450 ipm will freeze the regulator with a 35cfh flow rate....I would know....
    Quote Originally Posted by bubbaweld View Post
    2,970
    Quote Originally Posted by Steph Reed View Post
    Why is this?
    Thx - Steph
    As mentioned the reg could freeze up so Miller has to put the warning there BUT
    I've been running CO2 with the miller reg no problem.
    I'm just a hobby welder with some projects for my business so not a ton of heavy welding.
