    Default new Hobart Handler 210 mvp won't feed.
    brand new the unit fires up. re hooked the gun and connection....no go.....tried every position on voltage and wire speed.....no go.....switched polarity for straight wire......no go......flipped spool gun switch several times.....no go.....machine turns on and fan runs.....any suggestions? Thx. Dave
    3,936
    One of the wires came off the trigger...Bob
    8,101
    Jumper out the trigger terminals at the machine with a paper clip. Playing with the other crap does zero to help. Did the machine not come with an owners manual????
    Apr 2013
    metro Detroit
    91
    If it is new, take it back
    It has a manual. I heard they get stuck between voltage settings....reason I tried the other crap.
    Ended up being the big wgite plug inside that connects to board. Talked to Bill at hobart tech....very helpful.said some harnesses were wound too tight...that was the case and the plug wasn't "locked" in....Dave
    Quote Originally Posted by JerseyWelder View Post
    Dec 2012
    Front Royal, Va
    64
    Hobart has great customer service. Glad you fixed it. I have the same unit and love it.
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
    Wa
    621
    Glad it got solved. What do you think of the welder now?
    It blows my old handler 175 away......I like it more on small stuff than my old mm210....I am running .023 as I love it in these small machines. Gonna try my .035 Outershield E71M and CO2 soon .....dual shield fluxcore....
