Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Aug 2010
    1,174
    Quote Originally Posted by jrscgsr View Post
    I'll just throw my 2 cents in if the original poster is still alive. My old boss filled a diesel truck gas tank with water to weld a small repair on it, after a couple seconds of welding the tank suddenly ballooned and push him back. The residual diesel on the inside of the tank turned to vapor with the welding heat then ignited despite being filled with water. He was lucky and didn't get hurt, but honestly the only way to safely weld/cut a fuel tank is to use a degreasing cleaner first then purge the tank with a non reactive gas. If I can't do that then I don't work on it.
    Same thing happened to me years ago. Customer swore he flushed out the tank. It knocked me across the shop. Never again without purge.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  2. #22
    Jul 2010
    382
    Quote Originally Posted by Nathan128 View Post
    It's an oil tank. Oil burns not explodes.
    When oil vapor is at high temperature in the presence of oxygen, trust me – it explodes just fine.
    Oh, and by the way – an oil fire can kill you just as dead as an acetylene fire.
  3. #23
    Very true.....looks like Nathan got LUCKY.....like many do....some people are too stubborn to listen.....just cause it didn't explode this time doesn't mean it never will. Dave
    Quote Originally Posted by Helios View Post
    When oil vapor is at high temperature in the presence of oxygen, trust me it explodes just fine.
    Oh, and by the way an oil fire can kill you just as dead as an acetylene fire.
