Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Hybrid View
    Jun 2011
    New Milford ct
    75
    Default cutting heating oil tank
    Sure its been asked is sazall ok for cutting open a 275 gallon oil tank? My fire pit is done time for a new one.
    Dec 2012
    Simcoe Ontario
    103
    I've cut the 500 gal ones with a torch/plasma cutter. Just leave it vented. Oil doesn't explode just burns really. But it's your call if you feel comfortable.
    Nov 2003
    3,584
    Red face
    I have done it several times in building pig cookers..
    but prepped them first by steaming them out with a steam jenny to get the crud loose...
    I like the round oil tanks best for that purpose...
    run the sawzall slowly with a coarse metal blade and have somebody give it a squirt of WD40 from time to time to cool the blade.. (white smoke is good)
    also I usually tack weld a length of angle iron to the tank to be a saw guide...
    Word of caution... do not run the blade fast... you will knock off the teeth in nothing flat...
    post pics...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Oct 2005
    North Central Indiana
    782
    I turned the tank on it side and used my plasma and a come alongs snug cable to set the torch on and ride around the tank. Only had to move the come a long one tine brcause of the cranking mechinsm. Measured up from the concrete floor to get the cable level. My tank sprung when it was cut free, if I was to do it again I would run a 1/4" rod through the sides of the tank I was using and weld both sides to prevent the tank from springing open.
    wear ear protection, a jig saw with the right blade might be easier to control.
    Sep 2009
    South Carolina
    571
    Quote Originally Posted by makowicki View Post
    I don't see a problem with it.
    Oct 2005
    782
    I would think using a good jigsaw with the right blade would be more accurate and easier to work with.
    I should have run a couple rods through mine and welded them in-place, when the halves separated the ends sprang open.
    I used my come alongs' snugged cable for a straight edge. I turned the tank on it's side an measured up from the shop floor to get a level cut and straight cut.
    Dec 2012
    Simcoe Ontario
    103
    I've used a torch/plasma on the 500 gal ones before. Just opened all the threaded holes
    Dec 2011
    424
    Quote Originally Posted by Nathan128 View Post
    Not nearly safe enough for me.---Meltedmetal
    Jul 2010
    382
    Why? To ensure you allowed enough air into the tank to get that perfect oxy-to-fuel explosive ratio?
    Mar 2011
    st-eustache qc.canada
    243
    fill with water and use air tool grinder or sawzall.
