Results 1 to 2 of 2
    Default Lincoln SA200 Has no weld output.
    I have a Lincoln SA200 1975 that was welding ok (kind of cold by the settings). It stopped welding and now it has 109 volts on the AUX with no weld output.Where should i start? Thanks
    8,020
    - Failed local or remote rheostat,
    - Failed remote switch
    - failed generator or brushes to comutator, one of the 2 blue wires from the generator has broken
Tags for this Thread
