Results 11 to 20 of 20
    Nov 2003
    3,593
    Quote Originally Posted by mikesystem View Post
    Will I don't do very much of this and prob won't after this but this might go on for a few months but just can't drop 5 g on a unit to weld these things worst comes to worst I will have to keep tigin it but its taking to long I was thinking a millermattic 200 with a spool gun but not sure if that would work or not
    The MM200 with a 30A would be a good inexpensive short term solution..
    the MM200 is a lot more machine than the name would suggest...
    it is 200 amps at 60% duty cycle and 270 amps at 35% duty cycle..
    http://www.millerwelds.com/om/o1327ah_mil.pdf
    they can be found on the used market for between $400-600 w/o spoolgun..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    I am helping out a friends shop weld good size aluminum boxes and am welding with my dynasty 350 right now but it's way way way to slow and owner said they were wire welding them with spool gun or push pull set up Most the plate aluminum is 3/8 to 7/16 and they have been tacking on 1 in blocks to all four corners on these parts So my question is what set up would work for me ? I don't wanna spend the farm but would like to get a wire set up for this any advise would be great thanks in advance
    Don't know what kind of budget you have, but this is a good option
    http://www.millerwelds.com/products/...p?model=M00218
    Look at cyberweld or your local welding supplier. You can find the machine for about $2300.00
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Nov 2003
    3,593
    Quote Originally Posted by jpence38 View Post
    The MM252 is a decent machine... it has output and duty cycle nearly identical to the MM200...60% Duty cycle @ 200 amps.. will drive a 30A spoolmatic and it does have gun on demand which is convenient..
    figure 4.2 page 12
    http://www.millerwelds.com/om/o230693l_mil.pdf
    My Blue Stuff:
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    figure 4.2 page 12
    I have had both. The 350P and now the 252. I like the 4 roll drive on the 350P, but for the price, the 252 is a good machine. And as you stated, the 15A or 30A is an option and the gun I prefer over all the others.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    1,910
    Just to clarify don't mix up the older MM200 & the new multimatic 200, which can also be called a MM200. Two completely different units.
    I run a MM250 with a 30a spool gun on the heavier aluminum I do. It works fine. I'm in a situation like you where I don't use it much but when I do it gets used for a day or two all day. This set up, a MM200/250/251/252 with a 30a is what I would recommend. If you buy it used you can always recoup your cost when done by reselling it.
    Not knocking the 350p but if it's going to sit for long periods in the corner it doesn't make good business sense.
    Nov 2003
    3,593
    If you are going to run a spool gun.. you might as well bite the bullet and get either the 15A or 30A .... they weld well and are built to last and be used....
    some of the others not so much... they are just trouble..
    My Blue Stuff:
    8,262
    Lincoln MP350, with a Miller 30A spoolgun. One stop shop with Tig, Mig, Pulsed Mig, and Stick. always upgradeable software wise. Or for half the money a Lincoln MP300, which is the same as a MP350 with a simple software upgrade.
    illinois
    101
    If your not really looking for a mig id say continue on tiging. If u really wanted a good setup for a mig and aluminum. My suggestion is the lincoln c300 with a push pull gun. That machine is sweet. Pry get knocked for saying that on here but its my opinion. Its what id buy for a mig. Only miller migs i ever really thought were really good are the xmt with a 70 series feeder.
    Aug 2008
    113
    Default please help what to buy
    Would a spoolmate 15 or 30 do it running off a old millermattic 200 thanks ?
    Aug 2010
    1,173
    Yes, it can do it but not very well. It has no run-in control which really is the key to starting the weld on alum. The 350P,350P-alum, and the 252 has run-in control. Tell your boss if he wants you to go faster buy a mig with the ability to burn alum and has run-in control.
    The ThermalArc 252i Fabricator has run-in control, and you can buy a spoolgun for it.
    Or learn to tig faster.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
