Results 11 to 14 of 14
    Default SB tig braze help
    But bolting is the easier way
    Nov 2012
    Northern Arizona
    538
    Melted-
    This had mild steel glued on somehow and it fell out. I acquired this and just want to warm the shop with it. Might have had glass before. I ground a good layer off and it is definitely not white metal.
    Steve-
    Good to know about bronze. Why won't the sb melt to the bronze? This is my first time working with this metal. I like steel better!
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Nov 2012
    Northern Arizona
    538
    Is it worth SB mig wire? I could pick up a small spool of that too.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Oct 2013
    10
    I checked some sources and it looks like you should use argon or argon/helium mixture. You could even use pure helium if your welding a thick part. The trick is too get a puddle started and keep the arc in the puddle moving it forward when you add the next drop of silicon bronze. Do not focus the arc just on the brass. If the brass gets too hot the zinc in the brass will migrate out at you with a pop and a white hazardous smoke. Use DC and pulse of about 30 and background about 50% if you have the pulse option on your machine. You could also braze this project with a gas torch. Hope this helps. Have fun!
