    Apr 2013
    metro Detroit
    91
    Default question about stick welder amps
    the question I have is about the amps. I asked about stick welding 1/2 mild steel before and everyone said to use 250 amps (for single pass). So I know this probably basic info, but could I use a 200a machine and just do multiple pass. I have access to a 200a machine. I don't need to weld that thick but 1 or 2 times a year, so if I don't HAVE to buy a 250a I would wait to buy it.
    Thanks Dean
    NY
    99
    Unless your working on a skyscraper you should be fine with 1/8 7018 between 125&130amp dcrp, depending on your skill level.
    4,432
    Agreed, l I have bigger machines but this is what I use.
    Dec 2012
    Simcoe Ontario
    91
    200 amps is lots for anything but gouging. Just multipass it
    NY
    99
    Default amp question.
    Here's some 1/8 7018 at 125a.
    Sep 2009
    Canada
    189
    Not sure why anyone would want to attempt welding 1/2" steel in a single pass.
    Multi pass is the way to go. If you require a full 1/2" weld, 5/32" rod will make quick work of it.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
