    May 2010
    Central CA
    785
    Default I have a code number....
    I can get a SA-200 with code number 8023. The face plate was replaced and does not have a serial number. I got the code from the barrel.
    It's a first generation green light. The second generation green light has the warning face plate.
    My '84 is a warning lable, it's code is 8791. My '80 is a first gen green light, with a code number of 8244.
    So is there any way to find out what is the exact year of that SA-200 with code number 8023.
    Thank you,
    Good Luck,
    Bob
    PS. The only SA-200 I don't have is the post Red Face, Black Face that goes untill the first gen green light. So say '71 untill maybe '79.
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    2,954
    http://www.millerwelds.com/resources...SA-200-numbers
    maybe something in this thread can help
    Nov 2003
    3,690
    Quote Originally Posted by Bob Miller View Post
    Thank you,
    Good Luck,
    Bob
    Do not know about the exact year... but the owners manual for code 8023 was published in 1993.. may be revision date.
    Here is the link to the PDF
    #1
    http://www.lincolnelectric.com/asset...oln3/im276.pdf
    #2
    http://www.lincolnelectric.com/asset...oln3/im277.pdf
    also.. you can download other manuals and parts books by plugging that product code in here
    http://www.lincolnelectric.com/en-us...r-manuals.aspx
    If you would like an Operations/Service & Overhaul manual for the engine...
    it is a free download...
    http://igor.chudov.com/manuals/Conti...aul-Manual.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    May 2010
    Central CA
    785
    Thanks guys, good information.
    What I gleaned from all that is, Code 8023 predates my 1980 SA-200 by 1 code 8244.
    I tried to figure how many codes per year and that came out at about 2, but not always true. Not all codes went in order.
    8023 goes with the 8000 and below, and 8017 goes with 8200 and above.
    So all I know now is it is close to a '80 year model.
    sberry, the welder in that old post with the picture of you welding with that black face, looks like the first black face that came out after the red face years.
    Rounded top corners on the face plate just like the red face.
    What year is that welder? Or if you don't know the year, PM me with the serial number please.(first 3 if under 1 million, 4 if over, 1 million came in '83)
    I had a large folder with all the information I learned about SA-200s over the years, turned up missing. My wife says she has never seen it.
    Good Luck,
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
    Nov 2003
    3,690
    Bob
    you could always get the engine serial# and email it to Wisconsin/Continental..
    bet they could tell you when it was made...
    likely just a bit before near the time the whole welder was built..
    My Blue Stuff:
    8,325
    Certainly Not going to get you anywhere without a serial#. Guesstimate puts it anywhere between 1975 and 1980, but thats the furthest you'll get.
    Nov 2003
    3,690
    Wisconsin has an online search..
    Serial Number Search
    All Wisconsin Motors engines sold since 1939 have been issued serial numbers. Feel free to search our database and find information about your engine.
    http://wisconsinmotors.com/support_serial_search/
    My Blue Stuff:
    8,325
    For sure if'in he had a serial# which he doesn't, and if it was made in the states NOT in Canada. It would be easy to find the date.
    Nov 2003
    3,690
    Smile
    "Engine" serial number....
    can't hurt to try...
    My Blue Stuff:
