Results 11 to 18 of 18
    Nov 2012
    24
    Did the tip mod. Gun runs awesome!! This was my first 3 passes with it. .120 wall.
    3,927
    Quote Originally Posted by Ninja turtle View Post
    Hey Bob, can I get you to mod mine? Thanks.
    You sure can...Bob
    May 2014
    Northern AZ
    15
    Quote Originally Posted by Blacktail View Post
    Take your currently "Worthless Spoolmate 100 gun withthe little costly 186406 tips and throw all those little expensive $%*#$%saway.
    I have a "Worthless" Spoolmate 3035 that takes the same little 186406 tips. Will this solution work for me too?
    3,927
    Quote Originally Posted by 64Trvlr View Post
    I have a Worthless Spoolmate 3035 that takes the same little 186406 tips. Will this solution work for me too?
    Yes it will. It will make your 3035 not so worthless...Bob
    May 2014
    Northern AZ
    15
    Thanks for the reply Bob! It looks like it's easy enough to do.
    What tips am I be converting to?
    3,927
    Standard M-15 or M25 mig gun tips with a 1/4-28 thread...Bob
    May 2014
    Northern AZ
    15
    I was hoping that would be the answer, I have a ton of those tips.
    Thanks again for the help.
    Jul 2006
    alaska
    181
    I was reading this and I also have a 3035 running off a MM210. I had the problems some of you guys were having. Here is what I did, use ..035 wire, 4047 or 4043 and keep that stick out at about a half an inch or better and go to town. Now with 5356, turn wfs wide open, 700, then set volts to tap 5, then start ahead of your start(if that makes sense) to warm things up and run back over that place. I use to burn those little tips up too, but did I just get used it or does my machine or technique make a difference? 3/16 Aluminum BTW
