Results 1 to 5 of 5
    Nov 2012
    5
    Default Diversion 180 MVP - 240v vs 115V for Australian Plugs
    Hi,
    I have a Diversion 180, I just wanted to know, in Australia our power points are 240v. I have a 15A outlet, can i use the Multi voltage plug which is for 115v and with the NEMA 5-15P connector or do I have to use the 240v Multi voltage plug with the NEMA 6-50P connector??
    I have a lead which goes from the 15A plug types used in Australia to a NEMA 5-15R connector. Just wanting to know if Im able to use this with the Miller 115V/15A MVP or if I have to make up a new lead which makes use of a NEMA 6-50R connector on the other end to mate with the Miller 240v MVP...
    Do the Multi Voltage Plugs have any electrics inside of them or are they just so you can swap between 115v and 240v outlets???
    Los Angeles
    2,970
    Lightbulb
    The 120v wiring is different on the MVP system- it works differently than a machine like the dynasty that is also multi voltage.
    You'll need to make an adapter that uses the MVP 6-50p to the Aussie 230 wall receptacle.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Nov 2012
    5
    Thanks for the heads up mate! will make up a new lead then
    Cheers,
    Apr 2013
    14
    I think connection cable has 4 wires. Ground, common neutral (and other 240v hot leg), 120v hot and 240v hot. MVP plug just makes right connection.
    Sep 2013
    Florida
    13
    How do you like that 180? Im considering buying one in the near future
Warning: Function split() is deprecated in /mnt/stor3-wc1-dfw1/357822/357839/www.millerwelds.com/web/content/lib/footer.inc.php on line 86
