Results 1 to 3 of 3
    Oct 2013
    Default Maxstar 150 STH dead
    I have had my Maxstar 150 STH for many years and it has worked great. When I tried to turn it on yesterday nothing happened. I have checked the voltage before and after the switch and it is running around 119V-120V. I can't see any burnt contacts or solder joints and I cleaned all the plugs. I have zero voltage on the white wires going into the display board. It was working fine the last time I used it but it has been sitting for awhile.
    8,347
    PC1 is likely pooched, and is a $500 touch
    Exact thing happened to mine. Was working fine, turned it off to take a break, turned it on an hour later and dead. Wouldn't even give me a trouble code.
    It was out of warranty and dealer want around $600.00 + labor to fix. Not worth fixing or replacing, as far as I was concerned.
    I eventually got a bigger unit of a different color.
