Results 1 to 7 of 7
    Sep 2013
    16
    Default trouble finding where to buy bobcat service manual
    I have a miller bobcat 225g.
    It apparently has a problem with fuel flow.I noticed that the fuel filter is only less than half full while it struggles to keep running.
    I dont want to start taking it apart without a manual.
    Do I get a manual for the onan engine? Or is ther one for the whole machine besides the owners manual?
    Thanks. I love this website!
    Nov 2003
    3,328
    Smile Gummed carb??
    Quote Originally Posted by a12bsmilin View Post
    First thing to do is download the owners manual for your specific version of the Bobcat 225G...
    that is done by plugging in your welder serial number here...(free download)
    http://www.millerwelds.com/service/ownersmanuals.php
    this will tell you which engine you have...
    probably a P216... but better to double check..
    if it is a P216 (or that family)
    here is a link for FREE PDF download of the Engine Service Manual..
    http://www.cumminsonan.com/www/pdf/manuals/965-0762.pdf
    sounds like maybe a gummed carb and filter...
    I would drain the gas, replace the filter and put in fresh gas with some carb/injector cleaner and run it to loosen the gum..
    Probably some of one of those spray carb cleaners down the intake and let soak would not hurt either....
    There is a lot of varnish in modern gas...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    1,883
    For engine problems you want an engine specific manual usually not available through Miller. I got mine off ebay reasonably priced. Make sure you get all the numbers off of the engine itself. There should be a tag somewhere on the engine.
    Nov 2003
    3,328
    Wink
    Or download it for FREE from Cummins-Onan....
    My Blue Stuff:
    Oklahoma
    714
    The "half full filter" itself is not a problem.
    Griff
    Nov 2003
    3,328
    Thumbs up
    Here is a thread on that problem that might be helpful....
    http://www.millerwelds.com/resources...ler-225-g-carb
    My Blue Stuff:
    Apr 2007
    Eastern Ontario
    101
    Fuel line crack
    Fuel pump issue
    Carb float or jets.
    Try gravity feeding it fuel by using a small tank held above the carb. Problem gone then check the fuel lines and pump.
    Problem still there then it's in the carb. Haven't been into mine yet but starving can be a plugged jet or a sticking needle valve.
    The suction line on mine inside the tank had a small crack in it about half way down. Would run great with a full tank then start to stutter as the level dropped. Took a while to find but an easy fix.
