Results 1 to 10 of 12
Thread: Miller dealers
    Oct 2003
    Newhall, CA
    241
    Default Miller dealers
    Hey guys .....
    Is there some way to find out about authorized dealers in my area? I live in Newhall CA which is north of Los Angeles.
    many thanks ...
    Jorge
    Oct 2003
    22
    Sure call 1-800-4-a-miller
    they can get you help there finding out authorized dealers anywhere!
    by the way....are you looking for a new welder?.......or you need repairs?
    whoomp there it is
    Oct 2003
    Newhall, CA
    241
    looking to buy a new welder ... my very first welder at that. I am also entertaining the idea of a plasma cutter.
    Jan 2003
    160
    SOCALTA...........Dealers near you are
    Praxair.......santa clarita....phone is 661-284-3519
    Sims Welding..sylmar...........phone is 818-898-2222
    Airgas West...northridge........phone is 818-700-6475
    All with in 10 miles..............Let the quest begin.......Rock..
    SSCOTT@MILLERWELDS.COM
    ROCK
    Oct 2003
    22
    Default socal
    Which process are you most interested in?....I can help you on that....and gear for each process!
    whoomp there it is
    Oct 2003
    22
    For a plasma cutter I would choose a Miller or Hypertherm.The plasma cutter that would be most valuable to the home/shop/farm would be a Spectrum 375 Cytmate that has a rated for 5/16 inch 3/8,it has a quality cut of 1/2 inch,and sever 5/8.For sheet metal work I would go with a Spectrum Thunder that has a rated cut of 1/8 and quality at 3/16 because the thickest sheet metal is 1/8....but I would suggest a pacutter with more duty cycle but it all depends on your budget.You will also need a good sized shop air compressor.I would recommend ingersoll rand or emglo in the 40-80 gallon range to provide a good supply of air!
    Thunder: $900 +tax @ www.cyberweld.com
    375: $1,185 +tax @ www.cyberweld.com
    Thunder can be used on 115 house voltage and also 230 volt to even sever 1/4 inch
    375 is used on 230 voltage
    whoomp there it is
    Oct 2003
    Newhall, CA
    241
    Wooly,
    I am leaning towards an MM210 with the spoolgun and the Spectrum 375 or a Hobart equivalent. I have a good size Craftsman compressor.
    Jan 2003
    160
    SOCALTA.............The 375 Spectrum is the same as the Airforce 400. Just different sheet metal...............Enjoy the quest......Rock.. SSCOTT@MILLERWELDS.COM
    ROCK
    Oct 2003
    22
    mm210's alright but you should check out esab's impressive line
    whoomp there it is
    Oct 2003
    Newhall, CA
    241
    Impressive in what sense? Are they better built, less expensive, etc. My daily,weekly/monthly welding demands are not that great. Its mostly for fabricating stuff. Nothing demanding or of any significant thickness/density.
