Results 11 to 20 of 20
    Illinois
    596
    Quote Originally Posted by Gingerboy View Post
    Hood time and bury your face in there! Or you can practice on thick plate and start on the edge so all your follow up passes will be up against a straight line. Oh and dont start if you've been drinking beer all day lol.
    As far as beer goes, Keystone " LIGHT " may help. I'm sure Gingerboy will agree !
    NY
    98
    Quote Originally Posted by BD1:312310
    LMAO, yup!
    Sep 2013
    5
    thank you everyone for your help.
    Greatly appreciated.
    Stef.
    Sep 2013
    New Berlin, WI
    7
    I remember in school when we were doing 3/8" structural tests overhead with stick I'd have a heck of a time seeing what I was doing. My instructor simply said you must look through the smoke haha. Eventually you'll see through the smoke, sparks, and flames and you'll see the light. It just takes practice and muscle memory.
    Jun 2009
    las vegas
    227
    Its all practice. As far as light goes I use a old shirt on top of my head. And let it drape the back when im outside keeps from getting the red neck and the reflection in the back. With enough practice youll start seeing through the smoke
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
    Jan 2012
    Coos Bay Oregon
    20
    Default Newbie here, I can't see where I'm going. I don't see my line/mark... what to do ?
    Try center punching along your soapstone line, then connect the marks. Also try positioning the plate so you are welding at a slight angle away from yourself. This will give you a better field of vision.
    Aug 2013
    15
    It takes time to get perfect straight beads.. Plus body positioning your hood and a steady hand all put together will give you straight perfect beads..
    Montana, USA
    232
    Try pushing instead of pulling, so the stick doesn't obscure where you want the bead to go.
    Mar 2011
    5
    I had the same problem. Couple things that helped me:
    1. I have a 2 power cheater lens installed. This added clarity.
    2. A portable halogen light also helps.
    3. I put a piece of angle iron behind where I am welding (if the situation allows it). It reflects back and also helps.
    4. Practice, practice, practice. You will get better with time. Concentrate on the puddle.
    Oct 2013
    24
    what shade lens are you using i use a shade 10 for almost everything and put a clear lens on each side of the shielding lens
