Results 1 to 4 of 4
Thread: 180sd
    Sep 2013
    1
    Default 180sd
    I have acquired an older 180 SD. All worked great and then stopped. I only use this for tig. The light on the process switch does not light up. It does come on when switched to stick. Where do I go from here?
    Nov 2003
    3,518
    Smile
    Quote Originally Posted by quad3.5 View Post
    First step would be to download the owners manual here... plug in your serial number to make sure that you are getting the right version..
    http://www.millerwelds.com/service/ownersmanuals.php
    Then go to the chart on page 24.... 5-4. Troubleshooting
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Aug 2008
    Orange, TX
    1,216
    That process light only comes on when stick mode is selected indicating the weld output is on or in TIG mode when the foot peddle is pressed (or the finger switch is closed if torch is so equipped).
    If output isn't activated by the peddle or figure switch, check them for a failed switch, broken wire or bad connection at the 14-pin connector (pins A & B).
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Oct 2007
    Cave Creek Az
    1,048
    Disconnect the 14 pin plug on the foot pedal when going to stick mode.
