Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    Nov 2003
    3,841
    Thumbs up
    Thanks Galen..!!
    you are a valued technical resource....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  2. #22
    Nov 2003
    3,841
    Question 4943 for ALUSIL casting...
    A question came up the other day about welding up an ALUSIL engine block bracket on an old Porsche 928S4....
    is 4943 the correct filler..?? if not what is??
    Did a little looking around and could not find a good answer...
    this is a structural member but NOT cylinder liner...
    ALUSIL is common in many european engines...
    anybody have an answer..?? Galen??
    Here is a thread on ALUSIL
    http://www.millerwelds.com/resources...m-engine-block
    and some good info on ALUSIL from it..
    Quote Originally Posted by captkipp View Post
    Alusil as a hypereutectic aluminium-silicon alloy (AlSi17Cu4Mg) contains approximately 70% aluminium and 30% silicon.[1][2] This alloy was created in 1927 by Schweizer & Fehrenbach[3] of Baden-Baden Germany and further developed by Kolbenschmidt.[2]
    The Alusil aluminium alloy is commonly used to make linerless aluminium alloy engine blocks.[4] Alusil, when etched, will expose a very hard silicon precipitate. The silicon surface is porous enough to hold oil, and is an excellent bearing surface. BMW switched from Nikasil-coated cylinder walls to Alusil in 1996 to eliminate the corrosion problems caused through the use of petrol/gasoline containing sulfur.
    Engines using Alusil include:
    Audi 2.4 V6[1][5]
    Audi 3.2 FSI V6[5]
    Audi 4.2 FSI V8[1][3]
    Audi 5.2 FSI V10
    Audi/Volkswagen 6.0 W12
    BMW N52 I6
    BMW M62 V8
    BMW N62 V8
    BMW V12[6]
    Porsche 928 V8
    Porsche 924S I4
    Porsche 944 I4
    Porsche 968 I4
    Porsche Cayenne V8[3]
    My Blue Stuff:
    Millermatic 200
  3. #23
    Oct 2012
    yuba city, CA
    76
    Default actual alusil composition
    Quote Originally Posted by H80N View Post
    Below credit to Wiki:
    Alusil as a hypereutectic aluminium-silicon alloy (Al17Si4CuMg or A390) contains approximately 78% aluminium and 17% silicon.[1][2] This alloy was created in 1927 by Schweizer & Fehrenbach[3] of Baden-Baden Germany and further developed by Kolbenschmidt.[2]
    17% silicon content is a whale of a lot different than 30% silicon.
    The 30% content in Capt. Kidd's post is in error.
    http://www.steelnumber.com/en/steel_...p?name_id=1254
    The above link has equivalencies from US to European, etc. grades
    and compositions.
  4. #24
    Nov 2003
    3,841
    Quote Originally Posted by dave powelson View Post
    and compositions.
    Dave
    Thanks for the corrected info...
    that makes the U.S. Equiv out to be.... B390.0
    My Blue Stuff:
    Millermatic 200
  5. #25
    Nov 2003
    3,841
    I did find a German specialty rod for ALUSIL... that might be suitable..
    but I sure hate to order something from overseas if something domestic will do a good job..
    here is the datasheet..
    http://www.technolit.de/App/WebObjec.../Alusil-S.html
    Also found a source that claimed 4145 filler was suitable..
    http://www.weldingwire.com/applicati...pload/4145.pdf
    My Blue Stuff:
    Millermatic 200
  6. #26
    If the Alusil alloy is truly A390 then its chemistry is:
    16.0-18.0% silicon
    0.50% Fe
    4.0-5.0% Cu
    0.10% Mn
    0.45-0.65% Mg
    0.10% Zn
    0.20% Ti
    Remainder aluminum
    The German filler rod on the Techolit web page is nothing more than R4047 which is available at almost any welding distributor and has the closest match for silicon at 12%.
    4145 has probably the closest overall chemistry match:
    9.3-10.7% Si
    0.8% Fe
    3.3-4.7% Cu
    0.15% Mn
    0.15% Mg
    0.20% Zn
    On most filler metal selection charts 4043 and 4145 are normally listed for welding these types of castings (4047 and 4943 are interchangeable for 4043 in all applications).
    In a nutshell, 4047, 4145, 4943 or 4043 should work.
  7. #27
    Aug 2010
    Los Angeles
    1,184
    Quote Originally Posted by Hobart Aluminum View Post
    Awesome.
    Thanks!
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  8. #28
    Nov 2003
    3,841
    Thumbs up
    Just noticed and read this AWS article on 4943.. from Galen's answer
    http://www.nxtbook.com/nxtbooks/aws/...tid=Cover1#/36
    figured if I missed it... others may have also
    Really good background and alloy comparison...
    pretty cool..
    My Blue Stuff:
    Millermatic 200
  9. #29
    Aug 2013
    102
    I use 4943. It flows real nice.....welded up a 6061-tc angle frame the other day.....I still use 4043 for all cast repairs though...Dave
    pretty cool..
  10. #30
    Nov 2003
    3,841
    Quote Originally Posted by JerseyWelder View Post
    From all that I can see... 4943 offers superior performance to 4043 in welding cast as well..
    what is the reasoning in using 4043 for that purpose if you have 4943 on hand..??
    The merits of 4943 on TIG welding cast aluminum as opposed to other alloys like 4043 was the reason for starting this thread in the first place...and all points pro and con.. so if you could elaborate why... am sure many of us would like to hear..
    My Blue Stuff:
    Millermatic 200
