Results 1 to 8 of 8
    Default if u buy a millermatic can I...
    Use fluxcore wire
    Nov 2012
    24
    Yes
    Your sure for a 650 mp
    Nov 2003
    3,584
    Quote Originally Posted by trailerguy89 View Post
    If you meant MP65E.... Why NOT??
    the wire handling is going to depend on the feeder you use...
    http://www.millerwelds.com/om/o228d_mil.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    What feeder would you recommend
    2,933
    That machine looks to be 3-phase, just make sure you can run it.
    I really want to know what to do to make it portable
    Nov 2003
    3,584
    Question
    Portable..??? GULP....!!!
    Needs a 35KW 3phase genset... to give you all 650 amps out...
    gotta figure a decent sized truck to haul the MP65E...at about 640lbs..... the genset plus feeder and supplies ... probably another 2000lbs plus....
    You're not gonna haul that mess of stuff around in a half ton...
    My Blue Stuff:
