Thread: getting shocked
    Jan 2013
    19
    Default getting shocked
    I have a syncrowave 250 dx. I'm running on dc- every once in a while when I press the peddle to strike an arc my arm that is resting on my work bench will get shocked. It's extremely annoying and I can't figure out why it does this. It doesn't matter whether it's my torch arm or the other. And it's very random. I can't seem to find a pattern. Does anyone know what might be causing this?
    Sep 2009
    South Carolina
    571
    I got popped a couple times the other day, not the first time by a long shot.
    If things are damp, that seems to light me up. But the other day I just moved the ground right up next to the work and it didn't happen again.
    Good gloves go a long way but won't always prevent it.
    I did notice once that the arc was coming right out where the tungsten cap screws down onto the torch. The components seemed ok but that's where the arc would jump out.
    good gloves, keep dry, keep a good ground close to work. If all that fails set some wood up to prop on.
    Oct 2009
    306
    It's the high frequency on start up. Wear proper PPE (personal protective equipment) make sure you have a good ground and your equipment is in good repair.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    illinois
    103
    X2 on the high frequency. If you are sweating and gloves get damp it will get you every time. My hands sweat alot so i use seperate gloves for grinding handling etc and then a pair just for actual welding. If it bothers u that much and u are weldind steel u can turn the hf off and scratch start.
    Nov 2003
    3,819
    Smile
    Quote Originally Posted by ryarelliott View Post
    This sounds normal for TIG... either DON'T rest your arm on the bench or put something insulating between your elbow and the bench...
    ask any TIG welder... getting zapped comes with the territory...
    even more exciting during the sweaty summer months....
    you might try and move your ground (work clamp) directly to your workpiece or as close as you can get it tho shorten the path... that might help some.(as said before)
    you might do a search... there have been a lot of threads on it..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
