Results 1 to 8 of 8
Hybrid View
    Sep 2013
    2
    Default MIG gas regulator setting
    Hello,
    What should the pressure be on a MIG regulator?
    Most regulators come "pre set" to something..
    but nobody says what it should be?
    I'm not talking about flow rate.
    Yes, I do understand the concept of choked flow.
    I can get the proper flow rate with either lower pressure (10 psi)
    or higher pressure (80 psi), but it seems like the higher the pressure,
    the more the first blast of gas when trigger is pulled.
    Is that good, or just wasting gas?
    thanks
    Dec 2006
    Central Alabama
    39
    Not sure I fully understand and bear in mind that I am not a pro, but I have two gauges on my mig, one for the pressure in the tank (which has no adjustment) and one for the flow rate. The flow rate is in cubic feet per hour and I usually set mine in the range of 18-20 cfh. This is with the trigger pulled.
    Miller Challenger 172
    Hobart AC/DC Stickmate
    Older Sears AC Stick machine
    Oct 2009
    305
    30 CFH. You should have a dual gauge reg on the tank one gauge shows bottle pressure and hrs other is your working pressure.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Sep 2013
    2
    Thanks for your replies....
    Once again, I'm not talking about flow nor CFH.
    On a normal gas regulator, (ie. Acetylene) there are two gauges.
    One for tank pressure, other for line pressure.
    On a Mig regulator, there is tank pressure gauge and a flow meter.
    The line pressure gauge is missing.
    IF that line pressure gauge was there, what should the pressure be?
    I know that because of choked flow, the dynamic pressure
    will be lower when gas is flowing.
    So, if my regulator pressure (not the flow) is adjustable, what should that static/non flowing pressure be?
    thanks again.
    Feb 2013
    12
    Most run 15 to 20
    The main thing is not to panic or get excited
    Bobcat 250, MM 211
    B&D,Meltabo,Milwaukee
    Porter Cable,Dewalt,Makita
    Harris,Airco
    Ingersoll-Rand
    Evolution Rage 2
    40 AMP Plasma
    Nov 2003
    2,792
    Thumbs up
    Here is a link to a simple GMAW gas flow rate chart...
    Flow rates are in CFH... Cubic Feet Per Hour
    http://www.netwelding.com/MIG_Flow_Rate_Chart.pdf
    This should take the mystery out of it...
    ALSO
    Here is a video that may help to clarify things...
    http://www.youtube.com/watch?v=5bAJq_3XJOA
    Unfortunately some of this is sales pitch... but the basics are there and easily understandable..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    TONS of Non-Blue Equip, plus Mills, Lathes & a Rat Tail File..
    Nov 2012
    Northern Arizona
    447
    Jim is not asking about the flow rate. There is flow and pressure. I have a high pressure and low flow fixed regulator to run my air lockers in my jeep. It does .5 cfm at 100psi. Jim wants to know what pressure, in psi, that a regulator flows at a given cfm. I'd have to look but I think my Radnor flow meter is at 50psi output. Not sure though.
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
    Feb 2012
    Wa
    487
    Jim, why would you need this information? Just curious.
