Results 1 to 2 of 2
    Sep 2013
    Default Starfire 1 motor replacement?
    Recently given an old Starfire 1 and the Tecumseh OH-120 either needs a rebuild or a replacement. Any small engines out there that will bolt right up or is this a rebuild only? Haven't torn into the old engine yet, but was told it needed to be replaced. Early in the process but wanted to know my options.
    Thanks for any help.
    8,177
    #1 BEST option would be to repair the one you have. Lets go from there, cause finding the correct shafted engine might be a problem.
