Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Oct 2004
    Edmonton, Alberta
    8,350
    Yes, white off and on the center terminal. As for running better, I suppose. Kinda wishy washy on that. 120 Vac/230 vac, its just a duty cycle thing.
    Now, yes the machine will run if connected wrong, however, it'll heat in the wrong places and takeout the $$$ horizontal mother board.
    So while its apart, best to take the plastic end of a screw driver and tap in the top 2 boards. I like to RTV (automotive silicone) the edges of those boards in (prevents them from comming out)
    With a philips driver, hand tighten the 2 screws on top of that black cover. (Just hand tight (maybe 13 inch lbs) Tighten, and ltighten and red locktite the brass nuts behind the output studs
    Sep 2013
    8
    Please stand by. Trying to get in touch with the original user that set it up this way, and see what they were thinking. It was for some scientific project where they were (trying??) welding some very thin pieces of tungsten. I just want to use it for gun parts.
    Sep 2013
    8
    Got in touch with previous owner, and he had no clue why it was done this way. I guess I'll hook it up like the drawing says and see what happens. He did say it worked well on the lowest setting for the job they were doing with it (welding some very thin wires).
  4. #14
    I'm in the identical situation as the original poster - glad I found the thread. Quick question - was the Auto-Line feature on all Maxstar 200SDs? I hate making assumptions like that. I think mine is an older unit. SN LC507419
  5. #15
    Nov 2003
    3,720
    Default Yup.. You Have AUTOLINE
    Quote Originally Posted by kjchristopher View Post
    Here is the manual that matches your serial LC507419
    http://www.millerwelds.com/om/o2226n_mil.pdf
    Yours was built between Jan and Jul of 2002
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  6. #16
    Thank you H80N.
  7. #17
    Sep 2013
    8
    I switched the wires to match the diagram, but havent used it yet. Does anyone know if it will be detrimental to run this unit on a 220V 40 amp circuit? I believe the manual says 20 amp.
