Results 1 to 10 of 17
    Sep 2013
    8
    Default Maxstar 200 SD Wiring Question
    Hello All,
    Picked up a new to me Maxstar 200 and would like to inquire if anyone here knows the proper internal power connection? This unit has a 16 foot power cord with a 50 amp dryer plug attached, and a home made 50 amp to standard 110 pigtail. The unit runs connected to 110. I would like to run it on 230, but would like to make sure it is wired correctly. The fact that it has a long power cord makes me think it has a non Miller addition to it. I want to make sure I plug it in to 230 I dont fry it. If anyone can help it would be much appreciated. I can post pictures here, or email them, of the existing connections.
    Ken
    Nov 2003
    3,618
    Quote Originally Posted by kendog View Post
    Hello All,
    Ken
    That Maxstar senses the voltage and adjusts it has Auto-Line Power Management Technology
    Here is a link to the manual... just plug in your serial number to get the right version..
    http://www.millerwelds.com/service/ownersmanuals.php
    As far as proper 230vac wiring.. here is a link to wiring a 6-50
    look at post #34 good diagram.. (wiring is the same for the Maxstar & Dynasty 200)
    http://www.millerwelds.com/resources...in-smoke/page4
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Sep 2013
    8
    Thanks.
    I have all that. What I am interested in is the connection inside the machine.
    Where do the wires land for single phase 230 power. I am trying to determine if this machine has been altered.
    Nov 2003
    3,618
    Thanks.
    Try the schematic in the back of the manual...
    http://www.millerwelds.com/om/o2226as_mil.pdf
    My Blue Stuff:
    8,281
    Just don't use the red, black and white only. Nothing in the machine to look at....
    Sep 2013
    8
    Thanks H80N and cruizer. I have the schematics, but dont understand them that well.
    So, L1 (black) and L2 (white) of 230 single phase landed on 1 and 2 of the switch, and 3 at the switch with nothing, because there is no third or red wire?
    Thanks.
    8,281
    Yep, L1 & L2, nadda on L3. as thats for 3 phase.
    Sep 2013
    8
    This one has black on L1 and white on L3. The extra long power cord made me suspicious that someone was in there.
    Any advise?
    8,281
    THAT IS WRONG!!!!! L1 & L2 only!
    Sep 2013
    8
    I agree. It runs now, though I havent welded with it. Could it be damaged being wired this way? As I said, I dont savvy schematics all thet well. The L1,L2,L3 run from left to right in my picture, according to the corresponding wires from the switch to the circuit board. So I take white off of L3 at the switch and land it on L2 and I am good?
    Also, I am assuming it will run better on 230. Is that correct?
    Thanks for the time.
    Ken
