Thread: Steel ID
    Sep 2009
    South Carolina
    571
    Default Steel ID
    Have this pulley from a crankshaft, when I start the arc (tig) it sprays black soot out. It has a small chip next to the key slot. I left the soot on for the pic.
    Kind of like the reaction you get on galvanized parts except back instead of white.
    Machine parameters as they would be on SS. I wire brushed and used acetone.
    Nov 2003
    3,332
    Smile
    Likely porous cast iron soaked with oil... leaving soot as the oil burns off...
    and not steel at all
    castings can soak up oil like a sponge..
    have you tried to precook it with a torch??
    what type of car? engine model??
    that may give us some cluesas to material..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Sep 2009
    South Carolina
    571
    It looks like a stainless sleeve pressed into the outer gear. If it is a pressed
    fit I didn't want to heat it to much.
    Its really spiting back like it would without gas coverage. Its not necessary to fix it but I have to go fix the crank shaft it came off of also, and if it does the same I wont be able to heat it, its in the car with seals only a couple inches away.
    I think it was said to be an 87 Nissan 300 ZX 3.0 turbo charged,
    Nov 2003
    3,332
    Still sounds like a Loctite 660 problem to me
    http://www.henkelna.com/industrial/l...2944-12974.htm
    especially with rubber seals an inch or so away...
    you are a braver man than I ... to weld that crank...
    My Blue Stuff:
    Sep 2009
    South Carolina
    571
    Yea that looks pretty good. I sent it to him.
    This thing is gouged out on both sides of the key.
    I seen a pic of it this morning but I don't have the pic. Yea I'm a bit nervous doing something like that. If it does what the above done, there is no way.
    I probably should have put this back in motorsports, sorry.
    Nov 2003
    3,332
    Would be a very tough place to try and re-broach that keyway anyway
    My Blue Stuff:
