Results 1 to 9 of 9
    Mar 2012
    7
    Default Related to welding filters for an old Canox S-200 weld fume extractor
    Found one of these in great shape and cheap but no filters and I can't find any info at all.
    It looks like it was made by a Swedish company (Vendago AB) but that is a dead end also.
    Any ideas to retrofit or find original filters is appreciated.
    cheers ian
    Nov 2003
    3,519
    Smile
    Some pics sure would take some of the mystery out of it.....
    might even be helpful...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Mar 2012
    7
    Default Pics for Canox S-200 fume extractor
    Quote Originally Posted by H80N View Post
    The backside of the front cover shows evidence of some sort of a gasket that covered the inlet. There is a label referring to 3 different filters that require changing. The front cover has a large particle trap.
    There are 4 rails one on each side so it appears the filter slipped over these and the front cover sealed it.
    All the filters I've seen so far (Lincoln) won't physically fit. There all appear to be cellulose or polyethylene.
    Has anyone made a weld fume extractor or have experience with a non-factory build version?
    cheers ian
    Nov 2003
    3,519
    Quote Originally Posted by ibs740 View Post
    cheers ian
    Ian
    The pics are good... I would also take some measurements...
    the filters are most likely industry standard, off the shelf from somebody like "Airguard" ...... I would contact them and do some digging around their website..
    http://airguard.com/index.htm
    Here is an overview of their line..
    http://airguard.com/downloads/airguardallproducts.pdf
    and a quick overview of considerations and layout for weld fume extraction systems..
    http://airguard.com/downloads/Arigua...-2520Story.pdf
    Likely Airguard made the original filters for your CANOX S-200 to begin with.. and one of their reps will recognize the application...
    Also... Much of the CANOX line was really OEM MILLER stuff ... just in red instead of blue... so there may be a corresponding Miller item...
    My Blue Stuff:
    Millermatic 200
    Nov 2003
    3,519
    Smile
    Any chance of a pic of that label and/or the filter numbers??
    they may cross to some industry standard...
    My Blue Stuff:
    Millermatic 200
    Mar 2012
    7
    Default Filter label
    I can't get a decent shot so here's what it says.
    5 pcs F101:1 pce F102, 15 pcs F101: 1 pce F306
    It shows a table for F101 filter changes based on the static/differential pressure switch being lit. Every 5 F101 changes also change F102. On the 15th F101 change change F102 + F306.
    Thanks again
    ian
    Nov 2003
    3,519
    Were you able to contact Airguard to see if they had any info??..
    My Blue Stuff:
    Millermatic 200
    Mar 2012
    7
    Default Spoke w/ Airguard
    Hi,
    I spoke w/ airguard and they were a bit unclear about weld fume extractors. I think the majority of their sales are in HVAC or at least the guy I spoke with.
    They have raw filter media but only up to MERV 6.
    I'm going to call Miller, I've had good luck before sorting out an old Heliwelder (1968).
    Thanks Ian
    Mar 2012
    7
    Default Canox S-200 Fume extractor filters
    Hi,
    Thanks Ian
    I just spoke with Miller help and they didn't make this unit so back to square one.
    The polyester pillow batting and charcoal are starting to look attractive.
