    Jan 2013
    South Wales
    13
    Default problem with miller maxstar 150s
    Hi all
    A friend of mine had a miller maxstar 150s
    It will power up but when you try to strike up the power light flashes and it wont arc,
    Hes basically said to me if i can fix it i can have it (which will come in very handy as ive recently blown my old one up)
    Please can someone help me out as ive got projects mounting up in my garage haha
    Cheers
    Cori
    If you ain't burnin' you ain't learnin'
    8,224
    The power light will flash a code, so there should be breaks in the flashing. Quite likely though its pooched.
    Jan 2013
    South Wales
    13
    Can you think of anything it could be?
    I know i wont be able to do a grand ammount of work with the welder but at the moment im without a stick set so id love to sort it out if i could
    Cori
    Nov 2003
    3,582
    Smile
    Cori
    could you make note and report the flash sequence here??
    Likely that Cruizer can decipher and give you a diagnosis...
    he is a bit of a wizard on these matters...
    Also... have you downloaded the manual for this unit??
    here is the link... make sure that you search by serial number to insure that you are getting the proper version..
    http://www.millerwelds.com/service/ownersmanuals.php
    Posting that serial number here would be helpful as well..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jan 2012
    Sierra Nevada
    47
    Exclamation
    FYI...
    These machines don't live long being powered by generators*(...What are the chances that your friend has used this machine for portable applications?
    *I heard this from a reputable welder repair man
    Jan 2013
    South Wales
    13
    Hi im 80 % sure its never been run off a jenny
    Apparently the LED flashes constantly with no noise and ot flashes approx 2 times per second
    I looked at the manual the best thing i could compare it to was where it said it needs to be reset, would i just basically turn it on and off to do this?
    Hope someone can help
    Cori
    Nov 2003
    3,582
    Question
    Serial number??...........
    My Blue Stuff:
    Jan 2013
    South Wales
    13
    LE42018M
    Cori
    Nov 2003
    3,582
    Quote Originally Posted by cori_southwales View Post
    LE42018M
    Cori
    when I ran it ... this is what I got
    Search Results
    Serial Number: LE42018M
    Sorry, that serial number did not return an Owner's Manual.
    Please try again or use the model name search below.
    Could you recheck the number??
    maybe a mistake in reading it??
    or possibly a UK version not in the online database?
    My Blue Stuff:
