Results 11 to 20 of 21
    May 2013
    East Tenn
    148
    Default pitting in aluminum weld
    Awesome vid!!!!thx
    Oklahoma
    743
    Quote Originally Posted by jrscgsr View Post
    I've had contaminated gas weld fine on steel, stainless ect but on aluminum it really gets nasty. Just change the bottle out and try another test piece.
    Same here.
    Griff
    Oklahoma
    743
    Quote Originally Posted by Whetstone View Post
    I just did a little bit of goggleing, and it says that hydrogen comes from water vapor or grease. In the case of the mold plate it was definitely hot, especially by the time I got through half of it. I cleaned both the mold and rod with SS brush/scotch brite and acetone. The only place grease could be coming from is my gloves, which some times handle dirty steel. Generally I like to have two pairs of gloves, but am running on one pair now.
    While I am not blaming these issues on the welder I have never been able to make it produce satisfactory aluminum welds.
    attached are some recent welds that are also grainy and dull, but dont have the porosity issues (material is 1/4 x 2 6061)
    The pic you posted shows contamination in the bead. That is the "pepper" looking specs and the black soot at the start of the bead.
    Hydrogen can come from" just about" anything that isn't aluminum, argon or helium. Not just grease or water vapor.
    Griff
    ps
    Let us know how much argon is left in the bottle in use
    Aug 2004
    Milan Michigan
    1,892
    Okay, So it sounds like your blaming the welder.
    The way your post reads is that you have welded these before without a problem and the only difference was the welder.
    Tig welding 4" thick aluminum should be difficult with a 250 amp welder, what does it measure the other way.
    If you preheat to 400 F. then Okay.
    You also mentioned that you were grinding on it which can cause contamination from the grinding wheel ( I'm not sure if they call broken off pieces of grinding wheel, HYDROGEN )
    Is there something that may have soaked into this particular casting like oil.
    What are they used for.
    Is your argon turned up to high.
    Is your cup the same size as the last one.
    Is your cup dirty.
    These are some possibilities.
    Oct 2012
    yuba city, CA
    76
    Default porosity in cast mold plate?
    Hello, I have been having a few issues with aluminum lately, the worst being pitting in the weld, that has been driving me nuts. All of these issues only happen with a newer welder that I bought. THe welder in question is a 250 Snycrowave (sn# lg480049l). T weld looks ok on the outside, a little grainy and dull, but the bead is filled will gas pockets that only come out when ground down. ........
    1-If you're watching the puddle in action--normally one can see porosity forming, bubbling, coming up thru and around the puddle.
    2-The cast mold plate pic you posted looks like classic--just below the parent mold surface--fine, casting porosity--inherent to the casting.
    In 'normal' AL castings--porosity is ever present. (High end, investment castings have limited to zip porosity.) Trying to boil out and fill myriad, scattered casting subsurface porosity is an exercise in futility.....if the goal is zero porosity after machining.
    3-If you're getting porosity on wrought AL, then it's time to consider the usual suspects.
    4-Grabbing whatever type of filler rod to weld whatever type of AL
    can create other problems you don't need. Suggest studying what Alcotech recommends--despite the recco's of board pundits.
    5-Ditto the previous comments on preheating.
    Apr 2012
    Western Kentucky
    118
    Here is a MILLER video on the subject of "Aluminum Porosity"
    it's Causes and how to avoid/minimize it...
    http://www.youtube.com/watch?v=Yu3BtdERmFM
    By Tony Anderson, Head of Aluminum Technology Miller/ITW
    I noticed he never mentioned cleaning with acetone. He talked about some cleaning agent made by LPS? Wonder where you can get that stuff.
    Syncrowave 200
    Millermatic 252
    Spoolmatic 30A aluminum gun
    Miller Spectrum 625 X-Treme
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Two big fire extinguishers
    "I'm a slow walker, but I never walk backwards" - Abraham Lincoln
    Nov 2003
    3,834
    Quote Originally Posted by Gobysky View Post
    The stuff he mentions is LPS ZeroTri®Heavy-Duty Degreaser..
    http://www.lpslabs.com/product-details/597
    He just said it was a good one... there are many .... acetone being the most common..
    I do not believe he was excluding acetone...
    As far as locating a supplier...
    http://www.lpslabs.com/find-a-distributor
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Apr 2012
    Western Kentucky
    118
    Worth a try to compare. Thanks for the link.
    Syncrowave 200
    Millermatic 252
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Oct 2013
    24
    when i weld cast aluminum i blacken the part with acetylene soot . light the torch with just the acetylene on do not turn the oxygen on wave the torch on the part should turn black then turn the oxygen on preheat the part the black will vanish when it hot enough then weld away learned from a old buck with a funny hat and moustache
    illinois
    103
    Water can get trapped in the aluminum oxide and cause hydrogen when you weld on it.
    Heres a couple more things ive found happening to me.
    1. Check to make sure your tungsten isnt bending. If u weld at too high of amps for the size ur tungsten can bend. Then the heat from it will melt ur filler before it gets gas coverage and put contamination into the weld. Usually when this happens u can see the black speckles come from the filler.
    2. Try a new torch head. I had the problem u are describing one time at work. I traced it down to the torch. Once i replaced that it went away. I think there was a small leak inside the head that was putting coolant in with the gas. It wasnt enough to drip but was messing up my welds.
    3. I know this is pry a dumb one but ive seen it alot. Make sure u have a clean tungsten. Ive seen people touch it then keep on welding. It will melt off and contaminate the weld. Once i touch anything the slightest bit i stop and resharpen. If u do this trust me u will get sick of sharpening and get real good at not touching your tungsten.
