Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Sep 2011
    12
    Default pitting in aluminum weld
    Hello, I have been having a few issues with aluminum lately, the worst being pitting in the weld, that has been driving me nuts. All of these issues only happen with a newer welder that I bought. THe welder in question is a 250 Snycrowave (sn# lg480049l). T weld looks ok on the outside, a little grainy and dull, but the bead is filled will gas pockets that only come out when ground down. Material is 6061 or cast mold plate, I am using both 4043 and 5056 and have the same issues. thicknesses vary from 1/4 to up to 4" thick. some times I pre heat sometimes not. I have tried pure, thoriated and ceriated and have the same issues. I like to weld hot, but very my amps as needed with the pedal. Filler and base materials cleaned with acetone and SS brush or scotch brite pad. Attached is a picture of the pitting.
    I will try to make a sample tomorrow with more accurate info for amperage, material, cleaning, rod, ect with a before and after grinding.
    Sep 2011
    12
    here is a mold plate that got filled, and then scrapped because of all the pitting issues.
    Nov 2003
    3,565
    Is the new welder near a door or window??
    could you be getting a breeze blowing off some of your argon coverage??
    How many CFH Argon are you running??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2009
    306
    Possibly contaminated gas? Try changing out the gas cylinder and see if the problem goes away.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Sep 2011
    12
    THe welder, is not in a area where there is air flow, I have no issues with contamination welding steel/stainless. I have tried multiple CFH for 12 to 20. I suppose it could be a gas issue, but I have never been able to make this machine weld like my older 250 snyc. I have never had pitting, but the weld has been grainy and dull, no matter what I do with ac balance and filler.
    Oklahoma
    727
    Quote Originally Posted by Whetstone View Post
    Porosity in aluminum is caused by one thing and one thing only: Hydrogen.
    There are many causes for the trapped hydrogen but the machine is not one of them. Neither is the type of tungsten used.
    Griff
    Sep 2011
    12
    Where would hydrogen be coming from? Not enough pre-heat?
    Oct 2009
    306
    I've had contaminated gas weld fine on steel, stainless ect but on aluminum it really gets nasty. Just change the bottle out and try another test piece.
    Sep 2011
    12
    I just did a little bit of goggleing, and it says that hydrogen comes from water vapor or grease. In the case of the mold plate it was definitely hot, especially by the time I got through half of it. I cleaned both the mold and rod with SS brush/scotch brite and acetone. The only place grease could be coming from is my gloves, which some times handle dirty steel. Generally I like to have two pairs of gloves, but am running on one pair now.
    While I am not blaming these issues on the welder I have never been able to make it produce satisfactory aluminum welds.
    attached are some recent welds that are also grainy and dull, but dont have the porosity issues (material is 1/4 x 2 6061)
    Nov 2003
    3,565
    Here is a MILLER video on the subject of "Aluminum Porosity"
    it's Causes and how to avoid/minimize it...
    http://www.youtube.com/watch?v=Yu3BtdERmFM
    By Tony Anderson, Head of Aluminum Technology Miller/ITW
    My Blue Stuff:
