    Aug 2004
    Milan Michigan
    1,809
    Default I Failed on my job the other day.
    I was called out to work on heating & Cooling unit on the roof of a building.
    The coils are aluminum and when they installed hail guards they put a self drilling into the 3/16" aluminum header which was 1/16" away from the cooling fins coming out of the header.
    The fin was paper thin and by the time I had enouph heat to melt the 3/16" material it disinegrated the thin stuff.
    There were some holes that were a 1/4" away from the thin fins that I welded up without a problem butt I just could'nt fix the one.
    They would not allow me to delete the one fin and weld up the header tube.
    Plain and simple ( I met my match ).
    Dec 2012
    Front Royal, Va
    64
    Yeah that sounded tough to fix. Don't you hate it when it just cant be fixed properly. Sometimes the live and learn saying is so true. A new coil will solve the issue so it truly is able to be fixed. Good luck.....
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
    Sep 2009
    South Carolina
    571
    I don't get that many jobs and forget a lot of them that turn out ok.
    The jobs I couldn't do or turned down I never forget.
    Cave Creek Az
    1,051
    I certainly agree with that!!!
    Aug 2004
    Milan Michigan
    1,809
    In all my years, Its the radiators that have given me the biggest problems.
    Dec 2012
    Front Royal, Va
    64
    Yep, thin and dirty.
    HH 210MVP
    Spoolrunner 100
    Victor Oxy/Acet
    30 ton press
    A wife to worry me
