    Apr 2012
    Western Kentucky
    118
    Default I sure like my Spoolmatic 30A
    Welded this bracket to protect my transducer on my pontoon boat.
    Preheating with a propane torch makes a huge difference for a small project like this. Had a little porosity issue though. I set the machine at 25 volts & 530 wire speed the my MM 252. Wire size was .035. Gas flow 25.
    Syncrowave 200
    Millermatic 252
    Spoolmatic 30A aluminum gun
    Miller Spectrum 625 X-Treme
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Two big fire extinguishers
    "I'm a slow walker, but I never walk backwards" - Abraham Lincoln
    Feb 2013
    North Dakota
    29
    Looks pretty good. Good idea
    3,946
    Nice...Bob
    Sep 2009
    South Carolina
    571
    May as well put a brace from above down to the bend at around 45 degrees. Might keep someone from trying to use it as a foot step in and out of the water.
    People just don't think about what they are climbing on.
    May 2013
    East Tenn
    148
    Looks good man! Looks you got a pretty nice fish finder on your boat. I'm amazed with the clarity you can get now with some of the 3d mapping. See actual trees,brush and rock piles on the bottom. Heck, seems like you could almost treasure hunt with them. Lol
    good idea. I have the same spool gun you do. I like mine too. But what I really what is one of those push-pull guns. Too expensive though.
    Sep 2009
    South Carolina
    571
    I almost bought a spool gun a few months ago and still kind of want one. But I guess if I had pulled the trigger I would have only used it once other than practice.
    I know its to late to run out and get it when the need arrives because you have not got used to it. Guess I'm getting a little tired of buying equipment and not using it.
    Post more welds with it when you can, I already went to the end of the web and back but haven't seen enough spool gun work to make myself get one.
    Apr 2012
    Western Kentucky
    118
    Yea, I'll post some more when I do another project. I use my Syncrowave 200 for thinner aluminum, but found that when I need to weld the heavier stuff, the Spoolmatic works great. Preheating is the key I believe. The aluminum flows in the joint like solder in an electrical connection. I don't have much experience with these spool guns, but I picked up on it quickly.
    Syncrowave 200
    Millermatic 252
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Apr 2012
    Western Kentucky
    118
    Default An aluminum dog gate built using the Spoolmatic
    One of these days I'll post a close up of the actual weld using the Spoolmatic. I realize these guns are expensive, but the welds go lightning fast compared to using my tig welder.
    Syncrowave 200
    Millermatic 252
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
