Results 1 to 3 of 3
    Sep 2013
    18
    Default Miller Specials starting Oct 1st
    Can anyone tell me what the special offer will be from Miller starting Oct 1? I want to purchase a 211and I just missed the 15% off offer. None of my local dealers can tell me. Hopefully it will be worth the wait. Thanks
    Aug 2013
    8
    I don't know when the next one will be or what will be offered but you could only get the full 15% off if you bought $150 in extras, other wise you would recieve 5%, like I did. I'm still awaiting my rebate but can tell you that yea it is/was worth it. It welds extremly smooth once you figure out the settings (every welder is differant). Like it's been stated before the auto settings run hot and the wire runs fast, so the settings under the side panel will get you far closer then the auto.
    Good luck,
    Dave
    Sep 2013
    18
    Thanks for the information. I plan to purchase the spool gun at the same time so I hope to get the full rebate. From what I have read the 211 is the best machine in the compact category. I like the idea of being able to run it off a generator if needed in the field. Hopefully it will provide what we need.
