Thread: Cover for 211?
    Sep 2013
    Default Cover for 211?
    Just purchased a Millermatic 211 along with the heavy duty running gear and a cover. The cover won't go over the welder because of the back rest/tank rest. Has anyone modified the cover or know of another cover that will work?
    Mark
    2,957
    Put a small piece of wood behind the welder so it doesn't slide in to the tank rest.
    Sep 2009
    South Carolina
    571
    I got the cheaper version of the cart they sell with it.
    The back will block the air flow coming out of the machine if you run it with the welder pushed all the way back. I do keep it back when moving it with a piece of angle and a couple bolt pins at the front. Then pull it forward to run it.
    Didn't get a cover, but do keep a plastic bag over it.
    Sep 2013
    Thanks, I'll try that. Sounds like it should work.
    Feb 2011
    The GREAT State of Texas!
    158
    My 211 cover on my 211 - it on my home made cart.......
    Roger Troue
    Retired since 2004
    Miller 211
    Miller 200 Syncro
    Miller 375 Extreme
