Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    alabama
    755
    You need to brush your welds AFTER you finished welding them also and the problem should go away.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Sep 2013
    11
    Quote Originally Posted by fabricator View Post
    I see what your getting at but I think brushing afterwards makes for an ugly final product, not that rust is any better.
    make sure you are getting and using 304L (not just 304) tubing and that you are using the "L" version of whatever filler you are using. If you don't have the "L" version of the base material and filler you material will rust in the weld/HAZ.
    The reasons other have stated could also be the problem.
  4. #14
    Sep 2013
    11
    Here is a close up of another part I made that was used for almost a year including one new england winter. This looks great and is from the same metal supplier.
