Results 1 to 3 of 3
    Nov 2012
    Tallahassee Fl.
    9
    Default Mig or Tig or both?
    I just got a 1999 Miller Bobcat 225 NT. What is the best way to mig and tig with this welder? Thanks
    2,914
    http://www.millerwelds.com/service/o...uals.php?model
    Enter in your SN# to get the correct manual, it has the directions for running those 2 processes off the 225.
    You can also plug in a small mig machine to the Aux power and Mig that way but you are limited in power since the 225 only provides about 8,000watts and 35amps @240v.
    Nov 2012
    Tallahassee Fl.
    9
    Thanks for the info. What would be a good tig for me to find?
