Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
  1. #41
    Aug 2004
    Milan Michigan
    1,797
    Truck looks great, Now your at a new level, As far as being able to load things onto your trailer to bring back to the shop, Erecting steel, Using the boom to hold your suitcase feeder where you need it etc.
    Any way, Congradulations on your build.
  2. #42
    Oswego IL
    723
    Default since your plumbed...
    Now its time for a hydraulic air compressor! Also no worries on the oil overheating, a service truck crane is not non stop operation, , and is an open center hydraulic system, so it simply returns to tank when the crane is in idle postion...ie pto engaged pump turning. Also i would recommend running the truck at 1200 rpms or so, if you run a 7.3 or 6.0 injectors live much longer when they are being cooled properly.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
  3. #43
    Apr 2006
    TAXACHUSSETTS
    1,493
    [QUOTE=Tryagn5;313813]Now its time for a hydraulic air compressor! Also no worries on the oil overheating, a service truck crane is not non stop operation, , and is an open center hydraulic system, so it simply returns to tank when the crane is in idle postion...ie pto engaged pump turning. Also i would recommend running the truck at 1200 rpms or so, if you run a 7.3 or 6.0 injectors live much longer when they are being cooled properly.Ihave the aux idle controller to ramp up idle wasn,t sure where to run it at.Thanks for advice.Was going to put in the blue regulator pressure spring update also.I have a engine driven ir compressor with kholer 11.5hp gas engine 30 gal tank.It,s behind my O/A tanks.
    /QUOTE]
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
  4. #44
    Aug 2004
    Milan Michigan
    1,797
    I personally like the gas powered ingersorand compressor so that I dont have to have my truck running for hours at a time, My compressor will run for a good 4-5 hrs on 1 gallon, I dont think my truck will do that, not to mention the extra wear on the expensive diesel engine.
  5. #45
    Apr 2006
    TAXACHUSSETTS
    1,493
    agree 100%.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
