Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
  1. #31
    Apr 2006
    TAXACHUSSETTS
    1,481
    Default outriggers
    Here,s what I got.Pic of the p-side mounted,it is also welded to the outer rail.The d-side cut thru side rail I made to allow this side to slide out.And a pic of the d-side out rigger on the floor unmounted.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
  2. #32
    Aug 2004
    Milan Michigan
    1,721
    admweld, If you remember what my truck looks like, I have a full 20' long rack on my F-550, A compressor, the crane and the Miller Pipe pro and I weigh out at 16,680 lbs.
    My guess is that you will weigh between 15 and 16,000 Lbs. and your GVW should be 17,500 Lbs.
    I used to run with a 24,000 Lb plate but because I haul a trailer and my little backhoe and four 4'x 8'x 1/2"thick road plates I changed to a 28,000Lb plate.
  3. #33
    Apr 2006
    TAXACHUSSETTS
    1,481
    Portable I think I,m gonna weigh more then that.I willing to bet I,m gonna weigh 18,000-19,000-lbs
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
  4. #34
    Apr 2006
    TAXACHUSSETTS
    1,481
    Default pto is on/tank is fabbed
    Pic of pto and pump had to chop off some excess tranny material to get pump on.Tank laying on bench waiting for McMaster carr to deliver tank fittings for plumbing.Also pic of p-side outrigger mounted.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
  5. #35
    Apr 2006
    TAXACHUSSETTS
    1,481
    Tank is mounted, crane is running.Had 3 springs added to p-side main stack,single top helper replaced with a 4 pack helper,d- side 1 in the and a 4 pack helper on top.Truck is up about another 4".Weighed in at 18,600lbs,front tank empty back tank half full tack on another 36 gals of diesel on the number when fully fueled.Will snap a few finished pics and post later.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
  6. #36
    Aug 2004
    Milan Michigan
    1,721
    Wow, I would not have guessed that.
  7. #37
    Apr 2006
    TAXACHUSSETTS
    1,481
    Idid I knew I,m running heavy machine weighs 1800,air comp 500lb,deck weighs 3600lb.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
  8. #38
    Apr 2006
    TAXACHUSSETTS
    1,481
    couple of pics of it all done on the rig.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
  9. #39
    730
    This is a great thread. Thanks for posting, and oh yes your truck looks great.
  10. #40
    Apr 2006
    TAXACHUSSETTS
    1,481
    Quote Originally Posted by kiwi View Post
    Thank you.Glad you like.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
