Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default update
    This is what we got done so far.Also got the plateform welded to deck plate will take a pic tomorrow before I mount crane and after.This is a couple of pics of it all painted
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Aug 2004
    Milan Michigan
    1,865
    Admweld, I dont remember how many gallons but the tank I built measures 48" x
    8" x 16" which is 3.55 cu ft. There are 7.48 gallons per cu ft which comes out to
    26.55 gallons.
    My tank is about 3/4 full.
    My guess would be that I put 20 gallons in and have never had a problem.
    Hope this helps.
    Apr 2006
    TAXACHUSSETTS
    1,504
    26.55 gallons.
    Hope this helps.
    Portable I like that design I think that may work for fitting behind my underbody boxes along the frame rail.What gauge did you use I,m thinking 12 ga. should be fine also did you use hot roled or cold rolled to fab your tank,does it matter?
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Aug 2004
    Milan Michigan
    1,865
    AdmWelding, I used 12 ga. P&O, It doesnt give you mill scale on the inside after welding which can flake off.
    The nice thing about all hydraulic verses electric over hydraulic is you can run it all day without having battery issues.
    Apr 2006
    TAXACHUSSETTS
    1,504
    I was thinking cold rolled for the same reason mill scale coming off inside the tank.You think cold rolled 12 ga. is fine?Or do I need to use p+o, the reason I ask is I don,t now if it readily available from supplier.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default more pics
    It,s mounted couple of pics.Still need to plumb,fab and install tank,mount pto/pump.And mount outriggers but getting closer.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    4,487
    I think the 20 gallon is way over kill for that size unit?
    Apr 2006
    TAXACHUSSETTS
    1,504
    I have a 3-1/2" dia. boom lift cylinder.a telescoping cylinder inside the boom 2 outriggers.Portable suggested this size and has about the same crane.S berry last thing I want is to build a tank and run dry and wipe out my pump.More will stay cooler correct?
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Aug 2004
    Milan Michigan
    1,865
    Admweld., To be honest with you I cant say that Sberry is wrong or not, I built mine back in 1999.
    On the flip side I dont think that would have been something that I would have just guessed about.
    I dont have hydraulic out riggers so yes, You will need more volume than me.
    __________________________________________________ __________________
    What size are your mounting bolts and how many do you have.
    My crane bolts down on a 3/4" plate with four 1" bolts.
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by admweld View Post
    Better to have too much capacity rather than not quite enough. This larger quantity of fluid in the system will help to dissipate /absorb more heat. If over heating is a concern, you can weld some 1/16" plate rings around the outside of the tank to act as cooling fins like on an air cooled engine and or add an oil cooler in the return line to the tank.
