Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
    Apr 2006
    TAXACHUSSETTS
    1,502
    Default Next thing going on my rig
    Just picked this up Friday got the outriggers also.Need to build a mounting platform off my deck.Will post more pics as we progress.Gonna be awhile as I,m slamed with work right now.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Sep 2007
    Medford MA
    542
    Hope all is well
    Frank
    Aug 2004
    Milan Michigan
    1,806
    Congradulations on the crane, You wont be sorry.
    The only bad thing about your crane is that its 100' to short.
    Give me some crane specs:
    Make
    Capacity.
    Boom length
    Is it telescoping
    Is it full hydraulic or electric over hydraulic
    As far as out riggers, The bull dog 4" square tube have worked for me.
    You may need to add a leaf on which ever side you put the crane on.
    Apr 2006
    TAXACHUSSETTS
    1,502
    Default Specs.
    It,s Ekegard/Dakota 6000lb.pto driven.12' closed,hydraulic out to 16' and a 2'manual pull section.Got the hydraulic up and down out riggers with it manual pull out.I as thinking of adding a bigger stack of helpers on both sides of the rear.Gonna have a buddy/bodyman of mine respray it black before I mount it.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Oswego IL
    738
    Default springs
    Depends on the chassis but normally only crane side recieves the helper spring. Also crane normally goes on the passenger side if your curious.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    Apr 2006
    TAXACHUSSETTS
    1,502
    Quote Originally Posted by Tryagn5 View Post
    Kevin
    P-side that is where mine was going.So you think I,ll only need helpers on that side?Or should doing both sides in rear better?It,s goin on my 04-F-550
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Oswego IL
    738
    Default crane and springs....
    Quote Originally Posted by admweld View Post
    F550 chassis have a lot of options. Might not need any springs. Also depends on the box on the truck. Normally only do the crane side. Also u will need to set the engine rpm to 1100 to 1400. Do u know the pto speed the pump needs? I have never seen that make. Hopefully it came with hydraulic outriggers. If not add them manual one suck.
    Kevin
    XMT 304
    Miller Spectrum 625
    S22a
    Miller Legend 302
    Lincoln LN25
    Apr 2006
    TAXACHUSSETTS
    1,502
    Kevin
    The outriggers are hydraulic up and down.But manual pull out.My 550 has the low deflection kit from the factory I specd it that way.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Aug 2004
    Milan Michigan
    1,806
    When I bought my truck new it was just a cab and chassis so I had to put springs on it for that, on the driver side I have 11 leafs on the main and a helper pack which is 3.
    On the passenger - crane side I have 12 leafs on the main and a 3 pack on the helpers.
    Best of luck on the crane, Its a pain in the butt to build the hydraulic tank, all the piping, hoses and the PTO pump etc.
    But its all worth it when you get to use it.
    I have certain customers that hire me verses my competition just because I have the crane and they dont because I can move the heavy plates of parts around that have to be welded.
    So even though I dont get paid for the crane directly, I get the jobs because I do have the crane.
    Apr 2006
    TAXACHUSSETTS
    1,502
    Going to buy a hydraulic tank but have to do all the piping.How many gallon tank do you have portable?I,m thinking I need a 25gal.?
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
